Calculating Earth's Orbital Speed: Gravitational Field Equations
The discussion centers on calculating Earth's orbital speed around the Sun using gravitational field equations. The initial calculation incorrectly used Earth's mass instead of the Sun's mass, leading to a significant error in the speed result. The correct formula requires substituting the mass of the Sun, which is crucial for accurate calculations. The final correct speed of Earth in its orbit is approximately 29,700 m/s. This highlights the importance of using the correct celestial body mass in gravitational calculations.
xxabr
It can be assumed that the Earth, to a good approximation, moves in a circular orbit about the sun. Determine the speed of the Earth.
v2 = GMearth/r
mearth= 5.98x1024
R of Earth's orbit= 1.49x1011
G= 6.67x10-11
v2= (6.67x10-11)(5.98x1024)/ (1.49x1011)
v2= (3.98x1014) / (1.49x1011)
v= \sqrt{}2676.9
v= 51.7m/s
Now here's the problem. My teacher said that the answer to this question is 2.97x104m/s
What is it that I am doing wrong? D:
The important mass, the one that the Earth orbits, is the mass of the Sun.
Ohhhh. Okay, I got it. Thank you
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
