MHB Calculating elasticity of substitution help
To calculate the elasticity of substitution between goods x and y for the function F(x,y) = 10x^2 + 15y^2, the Marginal Rate of Substitution (MRS) has been determined as 20x/30y. The elasticity of substitution can be expressed using the formula 1/(1-ρ), where ρ represents the power in the utility function. Clarification is needed on the value of ρ, as the book's answer of -1 suggests a specific interpretation of the function. The discussion highlights confusion regarding the application of the formula and the concept of ρ in calculating elasticity. Understanding these concepts is essential for accurately determining the elasticity of substitution.
bart11
Calculate the elasticity of substitution between y and x for F(x,y) = 10x^2 + 15y^2
I was able to calculate the Marginal Rate of Substitution as 20x/30y but I'm not sure how to proceed past that. The answer in the book is -1. Any and all help appreciated!
Mathematics news on Phys.org
denote rho as the power.
Then elasticity of substitution is
$\dfrac{1}{1-\rho}$
If the power is different, you would have to use the formula.
$\dfrac{1}{1-\rho}$
Sorry but I'm not sure if I follow. Rho? And I believe the book taught us using the formula so I may be a little confused. Thanks for the help!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
