Calculating Electric Field and Voltage Between Parallel Conducting Plates
The discussion revolves around calculating the electric field strength and voltage between two parallel conducting plates separated by 10 cm, with one plate at zero volts. The electric field strength was initially calculated incorrectly as 9.5 keV, but the correct calculation using the formula V = Ed should yield a value in V/m or kV/m. Participants clarified that the distance used in calculations should not be halved, as the entire separation of 10 cm is relevant for voltage determination. The correct electric field strength was confirmed to be 9.5 kV/m, leading to the conclusion that the voltage between the plates can be accurately derived from this value. Overall, the discussion emphasizes the importance of unit consistency and proper application of formulas in electrical calculations.
tuggler
Two parallel conducting plates are separated by 10.0 cm, and one of them is taken to be at zero volts.
a. What is the electric field strength between them, if the potential 6.65 cm from the zero volt plate (and 3.35 cm from the other) is 633 V?
b. What is the voltage between the plates?
V = Ed
For a I got 9.5 keV which was from the formula: (633V)/0.0665m = 9.5eV E3.
For b I don't know what to do? The electric field is uniform so the electric field is just 9.5E3 and the distance will be 10cm/2 = 5 cm. But how can I get the correct answer?
(a) 9.5keV seems awfully low - check your units?
I don't see how you got that figure from your stated calcuation: 633/0.035=18086.
(b) you know the electric field between the plates and you know the separation, and you have an equation which relates these two values to the voltage. What's the problem?
Why are you dividing the 10cm separation between the plates by 2 to the "the distance"? What distance is that?
If you have 6V in 6cm, how many volts do you have in 10cm?
If there are 633 in 6.65cm, how many in 10cm?
Likes 1 person
My mistake, its suppose to be 633/0.0665 = 9.5keV and it is the correct answer.
And I made a stupid mistake. I thought they said half way between the plates which is why I divided it by 2. Thank you very much! I know what to do now.
633V/0.0665m = 9.5keV
You appear to be out by a factor of about 10^23 - check units.
Apart from that - well done.
The first question is about the electric field strength, and its unit is V/m or kV/m, or N/C.
eV is unit of work or energy, about 1.6 E-19 joule.
ehild
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
