Calculating electric fields due to continuous charge distributions
The discussion focuses on calculating the electric field at the origin due to a linear semicircular rod with a linear charge density. A participant questions the formula used, noting that the denominator should include a² instead of just a, as this affects the units and correctness of the electric field calculation. The integral setup is confirmed to be correct for a semicircular distribution, with clarification on the limits of integration. The importance of unit consistency in physics problems is emphasized, and the participant expresses gratitude for the guidance received. Understanding the derivation of the components, such as the cosθ factor, is acknowledged as well.
al_famky
calculating electric fields due to continuous charge distributions?
a question I came across doing some electric field questions, and the answer was really confusing.
Charge is distributed along a linear semicircular rod with a linear charge density λ as in picture attatched. Calculate the electric field at the origin
for the first question, the magnitude of E was calculated with dE=\frac{adθλ}{4\pi\epsilon_{0}a}, but why is there only one "a" in the denominator, not a^{2}? The final result was this equation \int^{\phi}_{-\phi}\frac{λcosθdθ}{4\pi\epsilon_{0}}=\frac{λsin\phi}{2\pi\epsilon_{0}} which makes sense only if the "a" was dropped.
Thanks to anyone who'd be willing to explain the answers!
Did you forget to attach the picture? Maybe I'm just stupid and don't know how to find it. I would want to make sure I understand the question correctly. The integral in your "attempt" goes from -\phi to +\phi. That makes me think that the rod is only a semicircle when \phi = \pi / 2. I'm guessing that's why it's called "semicircular" rather than "a semicircle". Is that correct?
Other than that, you're absolutely correct. It should be a^2 in the denominator of dE because otherwise the units are not even correct. As it is, the answer you've quoted has units of charge per unit length, which is the unit of electric potential, not electric field.
Finally, I'm assuming you understand where the factor of cos\theta in the integral comes from since you didn't ask about it specifically.
my apologies, I thought i did upload the picture.
But you got the gist of the problem from the without the picture anyways.
Unit check, the fundamental approach to going over problems---why didn't I think of that?
I do understand the cosθ, thanks for asking
Thank you for taking the time to reply!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
