MHB Calculating Element Count in Disjoint Volumes Using Venn Diagram
The discussion revolves around calculating the number of elements in three sets (A1, A2, A3) under different conditions of overlap. For pairwise disjoint sets, the total is simply the sum of individual elements, resulting in 11192. When accounting for overlaps, participants debate the correct method to include common elements, particularly focusing on the number of shared elements between pairs and all three sets. Misunderstandings about the overlaps lead to confusion in calculations, with one participant ultimately arriving at a total of 11172 after clarifying the overlaps. The conversation highlights the importance of correctly interpreting set relationships in Venn diagrams for accurate calculations.
Petrus
Calculate the number of elements in A1 U A2 U A3 if there are 97 elements in A1, 997 elements in A2 and 10098 elements in A3 in each of the following situations:
(a) The amounts are pairwise disjoint, i.e.
, too
(b)
(c) there are 10 elements in common for each pair of volumes and 4 elements common to all three sets.
(a)I get answer 997+97+10098
(b)10098
(c) is the part I think I do wrong, will attach a picture of my venn diagram.
for some reason I get problem to attaché the picture but i get a1= 73, a2= 973, A3=10074 so the answer is (that is wrong I think) 73+10+10+10+4+10074+973
, too
(b)
(b)10098
Hi Petrus!
Well, your (a) and (b) are right.
... so I guess we'll be waiting for your venn diagram...
I like Serena said:
Hi Petrus!
Hello Serena,
I can't uppload my picture but I explained how it looks like
Petrus said:
Hello Serena,
Okay. Let me upload then.
A and B overlap with 10 elements in common.
The 3 sets together have 4 elements in common.
This doesn't quite seem to match what you have...
Will it also be 6 on that A and C that you have not painted?
Well, A and C would overlap in 10 elements and 4 of those elements are shared by all three.
So yes, it will also be 6 in the remaining overlap of A and C.
Basicly I have missunderstand the problem:( I thought it was 4 on a and b and c(that is correct) BUT its 10 on a and b... Thanks Sirena for help!:) I get the answer that is 11172
edit: after reading this again I notice how bad I explained. Basicly it was suposted to be 4 on a and b, when I calculated i calculated with 10 :P Unfortently I am not a verry good explainer soo I hope this explain ok:)
Hmm, I get a different answer.
How did you find yours?
I get the rest 6 I can't uppload picture so I will just type what I get
10082+987+81+6+6+6+4=11172
97-6-4-6=81
997-6-4-4=987
10098-6-4-4=10082
Hope this give you a clue :P Thanks for the help as well Serena!:)
Petrus said:
997-6-4-4=987
This one doesn't seem quite right.
- - - Updated - - -
Petrus said:
10098-6-4-4=10082
And this one has the right result, but a wrong number on the left hand side.
- - - Updated - - -
hmm? How can I get correct?:S (its a problem that you answer through internet and if you answer correct it says 'correct' and I got correct:S?)
97-6-4-6=81
997-6-4-4=987
10098-6-4-4=10082
They should be like this:
97-6-4-6=81
997-6-4-6=981
10098-6-4-6=10082
97-6-4-6=81
997-6-4-6=981
10098-6-4-6=10082
That give me also correct?! Are you serious? This is bad that I can get correct from both...? I will talk to my teacher about this because its not good if I get correct from miss calculated + doing a wrong step
97-6-4-6=81
997-6-4-4=987
10098-6-4-4=10082
I don't understand what you mean, but your end result should be:
10082+981+81+6+6+6+4=11166
What I mean is that this is a problem I get from a program. We are supposed to write the answer and it says if its correct or wrong, I get correct from my 'wrong answer' and the correct answer. Thanks to you I know what I did wrong and the correct answer...
