MHB Calculating Elliptical Orbit Points & Flight Path Angle
To determine the points on an elliptical orbit where the speed matches the local circular orbital speed, one must equate the velocities of both orbits. This occurs at the periapsis and apoapsis of the elliptical orbit. The flight path angle at these points can be calculated using the equation tan(γ) = (e sin(θ)) / (1 + e cos(θ)), resulting in angles of 0 at periapsis and π at apoapsis. The discussion confirms that these are indeed the correct solutions, although some participants express uncertainty about the underlying methods. Understanding these calculations is crucial for analyzing orbital mechanics effectively.
Dustinsfl
Determine the location of the point(s) on an elliptical orbit at which the speed is equal to the (local) circular orbital speed. Determine the flight path angle at this location.
What equation(s) should I be using or thinking about for this?
Mathematics news on Phys.org
Hi dwsmith, :)
The velocity of an object in elliptical orbit is given >>here<< and that of a circular orbit is given >>here<<. So by equating two speeds you will be able to find values for \(r\). The equation for the flight path angle is given >>here<<.
Kind Regards,
Sudharaka.
Sudharaka said:
Hi dwsmith, :)
Kind Regards,
Sudharaka.
So the velocities are the same on the semi-major axis. That is, on the periapsis and apoapsis.
The flight path angle is giving by
\tan\gamma = \frac{e\sin\theta}{1 + e\cos\theta}
At periapsis, the angle is 0, and at apoapsis, the angle is pi.
So $\gamma = 0,\pi$? Is this really the solution?
Assuming you have done the algebra correctly, the answer is yes. I am not too confident about the method used since my knowledge about these kind of problems related to physics is quite limited. Hope some other member will be able to provide more insight on this problem. :)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
