Calculating EMF Around a Square in a Magnetic Field
To calculate the electromotive force (emf) around a square in a magnetic field, the formula ε = -d/dt Φ is utilized, where Φ represents the magnetic flux. The magnetic field is given as 4t²y, and the integration limits for the area should be adjusted to reflect the correct unit system, with SI units suggesting limits of 0 to 0.02 meters instead of 0 to 2. There is a consensus that the initial approach to calculating the emf is correct, but there are concerns about unit consistency. It is important to verify the units of distance, magnetic field, and voltage to ensure accurate results.
gadje
A square of side 2cm, in the first quadrant of the x-y plane, with a corner at the origin, is in a magnetic field pointing out of the page of magnitude 4t2y.
Calculate the emf around the square at t = 2.5s and give its direction.
\epsilon = - \frac{d}{dt} \Phi
Do I do it like this?
\epsilon = -\frac{d}{dt} \int ^2 _0 \int ^2 _0 4t^2 y \ dx \ dy
If so, then great. If not, what do I do?
Yeah, that seems correct as you are just using the definition of flux:
\phi = \int \vec{B} \cdot \vec{dA}
And subbing that into your above expression for the emf.
It looks correct but I'm not certain as I'm only a mere first year so you should probably get someone else to confirm.
It looks correct, but I would double check the units of distance, magnetic field and voltage. What system of units are you using for Maxwell's equations? I normally use SI units with meters, Telsa and Volts, so I would have set my upper limits at 0.02 rather than 2. However, if you are using CGS units it may be correct - just double check it.
Yeah, I screwed up the units in the OP; had them right in my paper calculation.
OK, good! I guess you're using SI units. I think with cgs (or, more accurately Gaussian) units there might be a speed of light factor involved.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
