Calculating Empirical Formula | Antimony & Sulfur Reaction
  • Thread starter Thread starter extraordinarygirl
    Formula
To determine the empirical formula of the compound formed from the reaction of 2.435g of antimony with excess sulfur, the total mass of the compound produced (3.397g) must be analyzed. Since all the antimony reacts and excess sulfur is removed, the mass of sulfur in the compound can be calculated by subtracting the mass of antimony from the total mass of the compound. This approach relies on the law of conservation of mass, which states that mass is conserved in chemical reactions. By converting the masses of antimony and sulfur to moles, the empirical formula can be derived. Understanding these principles simplifies the calculation process for the empirical formula.
extraordinarygirl
When 2.435g of Antinomy is heated with excess sulfur, a chemical reaction occurs. The excess sulfur is driven off, leaving only the compound. If 3.397g of the compound are prduced, what is the empricial formula of the compound?
:frown: I am not even sure where to begin with this question because we were only given examples of how to do the empirical formuala when given the masses of each compound. Could someone please give me a hand of hwo to get started! Thank you
Antimony is an element, not a compound. It's trivial, but it may be important if you are asked this.
Anyway, the trick here is to convert all the weights (that was expressed in grams), including the mass of sulfur in the "compound", to their respective mole amounts. You'll understand this was easy part of the question when you are acutally making the "empirical" formula of said "compound"
good luck!
I am not understanding how I am supposed to covert the weight of sulfur in the compound if I don't know what the compound is. Is is Antimony + Sulfur? And if it is, how am I supposed to know what the charge of Antimony is?
You are making it more complicated than it should. You don't have to "know" the compound to find the wieght of sulfur in the compound, you can do this in another very familiar way, which is called the law of conservation of mass and the empirical formula. The problem mentions these clues.
1. The antimony "in our box" reacts with "excess" sulfur.
2. The "excess" sulfur is then driven out.
3. Only the compound "in our box" remains.
Do you remember the law of conservation of mass?
extraordinarygirl, to clarify what Umabel is saying, there's an assumption you need to make in solving this problem that should help a lot. Since it says antimony is reacted with excess sulfur, you can assume that ALL of the antimony is in your final product. Therefore, any additional mass in the final compound is due to the sulfur in the compound. That should help figure out how to calculate the number of moles of reactants and products.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
