Calculating Energy Released by Sodium Reacting with Water
The discussion centers on the energy release from the reaction of sodium with water, specifically the calculation of energy released per gram of sodium. The balanced chemical equation is provided, along with the change in enthalpy at 20ºC, which is noted as -368.6 kJ for the reaction of 2 moles of sodium with water. The energy released per gram of sodium is calculated to be approximately 8 kJ. The conversation highlights that the explosive nature of the reaction is primarily due to the hydrogen produced reacting with oxygen in the air, which significantly increases the energy output. Participants emphasize the importance of understanding the underlying processes, suggesting further reading on hydrogen explosions for more detailed insights.
xpell
Hi! After watching a couple videos about the explosive reaction of sodium in freshwater and seawater, I felt curious and wanted to calculate how much energy is released. However, my Chemistry is super rusty and I think that my result is way too high (equivalent to almost 2 g of TNT per gram of sodium!) Would you please confirm or tell me where did I mess it up:?
The balanced equation for the reaction is:
2Na + 2H2O → 2NaOH + H2
Change in enthalpy for the reaction at 20ºC (ΔH20C) is: -368.6 kJ.
So, the energy released in the reaction = 368.6 kJ
Mass of 2Na (2 moles of sodium) = 23 x 2 = 46 grams
Energy released for 46 grams of sodium = 368.6 kJ
Hence, energy released for 1 g of sodium = 368.6/46 = 8,013 J ≈ 8 kJ (!)
PS. If someone is so kind to tell me how to calculate this under different conditions of water pressure / temperature, I'd appreciate it a lot too.
Chemistry news on Phys.org
The explosion doesn't come from the sodium reacting with water, but from the hydrogen reacting with the oxygen, so the total output is even higher (but involves process that you haven't listed).
I see nothing wrong with your calculation (I am assuming you got the ΔH from some reasonably reliable source). There are plenty of materials that have higher energy density than TNT, so there is nothing surprising here.
Likes xpell and Bystander
Hey, thank you, I didn't know this! Would you please tell me more or point me to further reading about it?
Just google hydrogen explosion. Produced hydrogen mixes with the air, reaction produces enough heat to ignite the mixture. Kaboom.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
