Calculating Flux through a Sphere using Divergence Theorem
CB4
Evaluate [URL]http://webwork.latech.edu/webwork2_files/tmp/equations/93/91cfe28c766cad38444f0213c651281.png[/URL] where [URL]http://webwork.latech.edu/webwork2_files/tmp/equations/59/a56001472f977192637ea927c607a61.png[/URL] and is the surface of the sphere of radius 6 centered at the origin.
Ok so I started by taking the divF to get 3y^2+3x^2+3z^2. Using polar coordinates I created the integral (from 0 to 2pi) of the integral (from 0 to pi/2) of the integral (from 0 to 6) (3r2sin2(theta)sin2(phi)+3r2cos2(theta)sin2(phi)+3r2cos2(phi)))r2sin(phi) d(phi)d(theta)d(r).
After all of that I simplified my answer down but I keep getting a huge number, 29314.82937, for an answer and it's incorrect. This problem seems very easy so I feel like I'm missing a very obvious step.
If it helps, instead of converting each term, convert them as a group to r^2.
That is a good idea, but I still didn't come out with the right answer.
Why are you taking phi from 0 to pi/2? It should be to pi.
That is the million dollar question. Thank you very much my friend.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
