Calculating force nessary to compress spring
  • Thread starter Thread starter nikelberry
    Force Spring
To calculate the force necessary to compress a spring by 3.6 cm, Hooke's Law (F = kx) is applied, where k is the spring constant (30 N/m) and x is the compression distance (0.036 m). This results in a force of 1.08 N. Additionally, using Newton's second law (F = ma), the deceleration caused by this force on a 0.12 kg mass is calculated to be 9 m/s². The discussion highlights the application of fundamental physics principles in solving the problem. The participant successfully completed their homework with the provided assistance.
nikelberry
The data for a ball and spring sensor is given below:
mass of ball = 0.12kg
spring constant = 30Nm-1
distance to be compressed = 3.6cm
Calculate the force nessary to compress spring by 3.6cm.
The deceleration which the force in (the 1st question) would cause in a mass of 0.12kg.
i seem to find this question quite tricky, mainly becasue I am not sure of what equation to use!
please me on this one!
What does Hooke's law tell you about springs and Newton's 2nd law tell you about acceleration?
yay! i got it! thanks for your help much appreciated!
and that's my homework done!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
