I Calculating Force on a Golf Ball when Putting on a Level Green
  • I
  • Thread starter Thread starter ashmoney
    Force
To calculate the force needed to putt a golf ball on a level green, it's essential to focus on the initial impulse rather than just force, as impulse is the average force multiplied by time. The mass of the golf ball is 45.93g, and the distance to be covered is 3.048m, along with the rolling coefficient of friction derived from a stimpmeter reading. A free body diagram and Newton's second law (F=ma) can help in visualizing the forces at play, but the key is to consider the initial momentum required for the putt. Additionally, the force of rolling friction will play a significant role in the deceleration phase after the initial impulse. Understanding these dynamics will aid in accurately calculating the necessary force for a successful putt.
ashmoney
I'm looking for advice on how to calculate the force needed to putt a golf ball on a level green a certain distance. I currently have the mass of the golf ball (45.93g), distance (3.048m), and the rolling coefficient of friction using a stimpmeter reading. I have started by creating a free body diagram and using Newton's second law (F=ma), but I am so unsure of where to go from here to include the required distance into this equation.
It's not force you need, it's the initial impulse, which is (average) force by time to give you the initial momentum from the initial sudden acceleration phase.
The force of rolling friction/resistance is relevant for the deceleration phase.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
