Calculating force we need to turn
  • Thread starter Thread starter k1mJo
    Force
To calculate the force needed to move a 60 mm diameter, 500 mm long cylinder weighing approximately 11 kg, one must consider whether the cylinder is rolling or sliding. If rolling on a flat surface with no friction, minimal force is required to initiate movement due to its balance. The force needed can be determined using the formula for rolling resistance, which is the weight of the cylinder multiplied by the rolling resistance coefficient. If there is no rolling resistance, no force is needed to overcome it. Understanding these principles is essential for accurately calculating the required force.
k1mJo
Hello
I have a cylinder that diameter is 60 mm,length is 500 mm and this is approximately 11 kg .If i want to move the cylinder,how much force do i need to move?
How i calculate this kind of cylinders?
are you rolling it? or is it sliding on it's circular face? what material is it being pushed on?
yes,it is being rolled and if u want to learn about friction value,it doesn't matter.
well, if no friction, and perfectly flat surface, I don't think you need very much force at all. it's so precariously balanced on a hard line, that it should fall forward (roll) at the slightest push.
rolling resistance is your weight (lbs or Newtons(kgs*9.81)) multiplied by your rolling resistance coeff. If no rolling resistance coefficient than no force to overcome that roll.
Thanx huntoon :), you say that we use this formula ( F=m.a) .
I didn't say that. I said the force you need to roll something is it's weight * its rolling resistance coeff.
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
