Calculating Friction Force for Moving a Crate Across a Rough Floor
  • Thread starter Thread starter jwang023
    Friction Homework
To calculate the force needed to move a 32 kg crate across a rough floor with a coefficient of static friction of 0.56, a free body diagram is essential. The equations for the x and y directions must be set up correctly, considering the applied force at an angle of 21 degrees below the horizontal. It's important to use the coefficient of static friction (μs) instead of kinetic friction (μk) as the problem specifies static conditions. The net forces in both directions must be analyzed, leading to two unknowns: the force (F) and acceleration (a), which may require an assumption for solving. A careful reevaluation of the free body diagram and equations will help clarify the solution process.
jwang023
to move a large crate across a rough floor you push it with a force of 21 degrees below the horizontal of F. find the necessary force to move the 32 kg crate with a coefficient of static friction of floor and crate is 0.56?
please show your attempt to solve the question .. Then we will help ..
Well, I went ahead and made a picture representing what I needed and what not. I than set the x and y directions to try to make equations to solve for the variables.
So, in the x direction, I had -(mu sub k) + Fcos21= ma
For the y direction I set an equation -mg+N-Fsin21=0
I wrote fk =mu sub k*N on the side for reference. I was stuck because I figured I have to find force first right?
have you drawn a free body diagram carefully?
In the x-direction the friction force is not(mu sub k) this is not a force?, and another thing you are not given (mu sub k) you are given (mu sub s) don't you think you should use it?
I suggest you to do the free body diagram more carefully this time ..
You know that, Fx(net)=ma and Fy(net)= zero .. You are given the mass m=32kg and (mu sub s) substituting in the equations you will end up with 2 unknowns F (what the question wants) and a (the acceleration) , so do you have to make a certain assumption ? Try to think about it and let us know your answer :) ..
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
