Calculating Gate's Torque, KE & Angle When Bull Rushes Out
  • Thread starter Thread starter tachu101
    Angle Torque
The discussion focuses on calculating the torque, rotational kinetic energy, angle of rotation, and whether a gate will close when a bull rushes toward it. The torque applied by the farmer is calculated as 300 Nm. The rotational kinetic energy after 3 seconds is determined to be 405 J, and the gate rotates 1.35 radians in that time. Since 1.35 radians is less than the required π/2 radians to close the gate, it will not be closed in time. The calculations emphasize the importance of using proper units for energy and understanding angular motion principles.
tachu101
A gate to a bullpen is open at a right angle to the fence and the bull is rushing toward the opening to get out. The farmer estimates that the bull will reach the opening in 3 sec. so he pushes at the end of the gate (always at a right angle) with a force of 100N. The moment of inertia of the gate about the hinge is 1,000 kg m^2 and the gate length is 3.
a. What is the magnitude of the torque applied by the farmer.
b. What is the rotational kinetic energy of the gate after 3 seconds
c. Through what angle will the gate have rotated after 3 sec.
d. Will the gate be closed.
Torque, KE roational, Angular Kinematics
a. Torque= rFsin(theata) = (3)(100)sin90= 300Nm
b. KE= (1/2)(I)(w^2) = (1/2)(1000)(?)
c. angle= at^2/2?
d. ?
Part a is correct; for parts b, c, and d, you first need the equation (derived from Newton's 2nd law) that allows you to calculate the angular acceleration caused by a net torque.
If I use torque=Ia and solve for a I will get a=torque/I = (300)/(1000) = .3 rad/sec^2 as the angular acceleration. For the w value after 3 sec it would be .9rad/sec? So I could then do the KE= (1/2)(I)(w^2) = (1/2)(1000)(.9^2) = 405 Then for part c could I use Theta= at^2/2 and get (.3)(3^2)/2 = 1.35 radians. Is any of this right? What would I do for the last part?
Yes, excellent. Don't forget the units for energy, 405 __? For the last part, you know that the gate has rotated 1.35 radians. How many radians would it need to rotate to a completely closed position, given that it started out at a right angle to the fence?
pi/2 would be the angle needed to close the gate, but 1.35 is less than pi/2, so it would not be closed in time.
Correct. Now don't forget the units for the kinetic energy.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
