MHB Calculating G's Distance from BH on an ABCD.EFGH Cube
  • Thread starter Thread starter Monoxdifly
    Cube
In an ABCD.EFGH cube with a side length of 8, the distance from point G to line BH is under discussion. The initial calculations yielded $$\frac{8}{3}\sqrt6$$ cm, which does not match any of the provided answer choices. Participants confirm that the cube's structure is understood as having the base ABCD with vertical sides EA, FB, GC, and HD. There is agreement on the interpretation of the cube's geometry. The conversation highlights a potential issue with the answer options provided.
Monoxdifly
MHB
In an ABCD.EFGH cube whose side length is 8, the distance between the point G and the line BH is ...
A. 4 cm
B. $$4\sqrt2$$ cm
C. $$4\sqrt3$$ cm
D. $$8\sqrt2$$ cm
E. $$8\sqrt3$$ cm
I got $$\frac{8}{3}\sqrt6$$ cm. Do you guys get the same answer?
Mathematics news on Phys.org
A. 4 cm
B. $$4\sqrt2$$ cm
C. $$4\sqrt3$$ cm
D. $$8\sqrt2$$ cm
E. $$8\sqrt3$$ cm
I agree with you: $\frac83\sqrt6$. It's odd that in two separate problems the answer does not appear in the list of choices.
I am getting these answers on the assumption that "an ABCD.EFGH cube" means a cube where the base is ABCD, and the upper vertices are above the corresponding lower ones, so that EA, FB, GC and HD are the vertical sides. Presumably that is what is intended?
Yes, that is what's intended.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
