Calculating Halley's Comet Period and Next Approx. Viewing Date
  • Thread starter Thread starter carney
    Comet Period
Halley's Comet, with a semi-major axis of 17.96 AU and an eccentricity of 0.9673, last passed perihelion on February 9, 1986. The period of the comet can be calculated using the formula T = 2π(sqrt(a^3/μ), where μ corresponds to the Sun's gravitational parameter, not Earth's. The discussion clarifies that comets orbit the Sun, not Earth, which is crucial for accurate calculations. Participants emphasize the importance of using the correct gravitational parameter for Halley's Comet to determine its orbital period and future viewing dates. The consensus is that calculations should be based on Halley's orbit around the Sun.
carney
Halley’s Comet passed perihelion on 9 February 1986. It has a semi-major axis
a = 17.96 AU and eccentricity e = 0.9673. (One astronomical unit (AU) is the distance
between the Earth and the Sun.) Calculate the period of Halley’s Comet and the
approximate date on which you might next see it.
Period = T = 2pi(sqrt(a^3/u)
I realize all this information is available over the internet but I need to work it out by hand.
I attempted this question first using the value for 'a' given and the standard gravitational parameter (u) of Earth 3.986E14 but realized this is wrong and that halley's comet would have a different value of (u). I assume the equation for the value of (u) of halley's comet will be related to its eccentricity but can't seem to work it out. Any ideas?
In determining (u), what does Halley's comet orbit?
i just assumed from the question that it was orbiting earth.
What do comets typically orbit?
thats a very bad assumption. they orbit the sun and i can just look that value up. but using what I've been given and only those values is it possible to work this question out?
:eek:
It is an excellent assumption.
carney, I give you my blessing to assume your calculations are meant to have Halley's comet orbitng the Sun, not Earth.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
