Calculating heat released from excess enthalpy
  • Thread starter Thread starter rwooduk
    Enthalpy Heat
To calculate the heat absorbed or released during the mixing of a gas and liquid, the heat of mixing, or excess molar enthalpy, must be determined. This involves calculating the change in enthalpy (ΔH) using the initial and final enthalpy values of the mixture, which can be derived from the heat capacity and temperature of each component. The equation Q = nΔH is used to find the actual heat released (Q), where n represents the number of moles involved. A negative ΔH indicates an exothermic reaction, while a positive ΔH signifies an endothermic reaction. For further assistance, consulting a chemistry textbook or tutor is recommended.
rwooduk
Hello,
I am currently trying to determine the method to calculate the heat absorbed / released when a gas and liquid mix. I believe that this is known as the heat/enthalpy of mixing (or excess molar enthalpy). I also believe, that if this value is negative it means an exothermic reaction (heat released), if the value is positive it means an endothermic reaction (heat absorbed).
I'd really appreciate some direction on where to go from here. How would I calculate the actual heat absorbed/released from the heat of mixing value.
Thanks for any help.
Chemistry news on Phys.org
Hello,
Calculating the heat released from excess enthalpy can be done using the following equation:
Q = nΔH
Where Q is the heat released, n is the number of moles of the substance involved, and ΔH is the change in enthalpy (in joules/mol).
To calculate the excess molar enthalpy, you will first need to determine the initial and final enthalpy values for the gas and liquid mixture. This can be done by using the heat capacity and temperature of each component.
Once you have these values, you can use the equation:
ΔH = Hfinal - Hinitial
Where ΔH is the change in enthalpy, Hfinal is the final enthalpy value, and Hinitial is the initial enthalpy value.
If the resulting ΔH value is negative, it means that the reaction is exothermic and heat is released. If the value is positive, it means that the reaction is endothermic and heat is absorbed.
To calculate the actual heat released or absorbed, you will need to know the amount of substance involved (in moles). You can then use the first equation mentioned to determine the heat released or absorbed.
I hope this helps. If you need more specific guidance, I suggest consulting a textbook or reaching out to a chemistry tutor for further assistance. Good luck!
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
