Calculating how fast distance changes between ships
  • Thread starter hsd
  • Tags
    Ships
In summary, at 4:00pm, ship A and ship B are separated by a distance of 200km with ship A heading south at 30km/h and ship B heading north at 20km/h. The initial distance between the two ships is 50km. Using Pythagoras' theorem, the distance between the two ships can be calculated as well as the mutual speed between them.
hsd
At noon, ship A is 50km west of ship B. Ship A is sailing south at 30km/h and ship B is sailing north at 20km/h. How fast is the distance between the ships changing at 4:00pm in km/h.
http://img822.imageshack.us/img822/2420/shipq2.png
but the final answer is coming out wrong
I don't understand the very first line of your answer. Why are you taking the squares of the velocities? Where is the 50km in this? If you substitute t = 0 in your equation, what number should you get?
Ship A is heading south at 30 for 4 hours so travels 120 km. Similarly B travels 80 due north.
So they become separated by 200km north/south.
They are separated by 50 km due east west to begin with.
So the distance between the ships is? (pythagoras).
The angle of the same triangle is also the direction cosine of the motion so you can use that to calculate their mutual speed.
Related to Calculating how fast distance changes between ships
1. How do you calculate the speed of a ship?
The speed of a ship can be calculated by dividing the distance traveled by the time it took to travel that distance. The formula for speed is speed = distance / time.
2. What units are used to measure the speed of a ship?
The most common units for measuring the speed of a ship are knots (nautical miles per hour) or kilometers per hour. However, other units such as miles per hour or meters per second can also be used.
3. How do you determine the distance between two ships?
The distance between two ships can be determined by using a navigation tool, such as a GPS system, to track the coordinates of each ship. The distance can then be calculated using the coordinates of each ship.
4. Can the speed of a ship change during its journey?
Yes, the speed of a ship can change during its journey. Factors such as wind speed and direction, ocean currents, and the weight of the cargo being carried can all impact the speed of a ship.
5. How accurate are speed calculations for ships?
The accuracy of speed calculations for ships can vary depending on the method used to measure the speed and the external factors that may affect the ship's speed. However, with advancements in technology and navigation tools, speed calculations for ships can be quite accurate.
