Calculating Impact Speed of Meteor Falling from 811 km
A meteor falling from 811 km with an initial speed of 83.0 m/s will experience a change in potential energy as it descends, which can be calculated using gravitational potential energy formulas. The correct approach involves using energy conservation principles, where the decrease in gravitational potential energy equals the increase in kinetic energy. The formula V=GMm/R+r - GMm/R can be used to find the velocity just before impact, incorporating both the initial velocity and the change in height. It's emphasized that mechanical energy is conserved, and the kinetic energy formula KE = 1/2 mv^2 is crucial for these calculations. Accurate calculations require careful consideration of the Earth's radius in the potential energy equations.
strugglin-physics
A meteor has a speed of 83.0 m/s when 811 km above the Earth. It is falling vertically (ignore air resistance) and strikes a bed of sand in which it is brought to rest in 3.31 m. What is its speed just before striking the sand?
So here is the formula that I have but it doesn't give me the right answer.
v=square root of (Vi^2 + 2G(Mass of the Earth)/(Radius of the Earth*1-1/3.31)
I get 9337.6 m/s.
Does anyone see where my mistake is?
Use the following expression for potential energy
V = -GMm/r
In the r above, don't forget to inculde Earth's radius too.
Use energy conservation for the initial point and the point just before striking.
You don't need to do anything with the sand
spacetime
www.geocities.com/physics_all/index.html
With the above equation, you need to use it twice! You must find the difference in PE between the two distances from the Earth's center. THe change in PE equals the gain in KE.
It occurs to me. Wouldn't it be neat to see a meteor that ignores air resistance?
So you mean use the formula
V=GMm/R+r - GMm/R and that will give me the velocity just before it hits? What about the initial velocity? Does that go in there somewhere?
As Vector Sum and spacetime have explained, mechanical energy is conserved. This means that the decrease in gravitational PE will equal the increase in kinetic energy.
V=GMm/R+r - GMm/R and that will give me the velocity just before it hits? QUOTE]
That forumula is correct for increase in KE.
Remember KE = 1/2 mv^2. This formula ought to be imprinted on the inside of your eyelids.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
