Mathematica Calculating Integral in Mathematica
The discussion focuses on numerically calculating a double integral involving a multivariate Gaussian function in Mathematica, specifically for the function f(x) defined as a double integral itself. Users encountered errors when attempting to evaluate the integral due to the lack of a closed form for f(x). A successful approach involves reordering the integration limits and using the NIntegrate function correctly. The final solution suggests defining f[x, c] as a function that integrates the PDF of the multivariate normal distribution, allowing for repeated evaluations over a range of x values. The conversation concludes with users expressing satisfaction with the provided solutions and code examples.
jimmy1
I have a function f(x) which is defined as
f(x) = \int_{x}^{c} \int_{x}^{c} f(x_1,x_2) dx_1 dx_2
where c is a known constant and f(x1,x2) is a multivariate Gaussian. Unfortunetaly there is no closed form solution for f(x).
My problem is I want to numerically calculate
\int_{c_1}^{c} f(x) dx
where again c_1, and c are known constants.
How do I numerically evaluate such an integral in Mathematica? I get errors every time saying "x is not a valid limit of integration".
Any ideas, how I would input the above into Mathematica to get a numerical solution?
NIntegrate[ f[x], {x, c1, c} ]
where c1 and c are numerical values or constants (like Pi, 2*E, 33.401 etc).
Unfortunately f(x) has no closed form solution (so the expression for f(x) still has the symbols x1, x2) and thus evaluating "NIntegrate[ f[x], {x, c1, c} ]" just gives the error the "Integrand ... is not numerical at...".
I've also tried "NIntegrate[ f[x], {x1, x, c}, {x2, x, c}, {x, c1, c} ]", but this gives the error "x1 = x is not a valid limit of integration. "
I'm sure there's some way to do it, but just can't figure it out?
Can you post some code, in particular be a little more specific about f(x1, x2) ?
Basically, f(x1,x2) is a http://en.wikipedia.org/wiki/Multivariate_normal_distribution" . An example in Mathematica code would be:
f(x) = "Integrate[PDF[MultinormalDistribution[{5,6}, {{1,1}, {1,2}}], {x1,x2}], {x1,x,c},{x2,x,c}]"
For any particular value of x and c (c is a known constant) I can numerically evaluate the above expression, however, I want to evaluate the above expression for all possible values of x, where x is a countinous number, and hence I need to integrate the above expression for all possible values of x (say, x ranges from 0-10 in the above example)
You are right that
Code:
doesn't work, but I think that
Code:
NIntegrate[ f[x], {x, c1, c}, {x1, x, c}, {x2, x, c} ]
does. At least it gives an answer... apparently the integration is in a different order than you'd expect.
E.g.
Code:
NIntegrate[PDF[MultinormalDistribution[{5, 6}, {{1, 1}, {1, 2}}], {x1, x2}], {x, 5, 10}, {x1, x, 10}, {x2, x, 10}]
0.365427
Of course, make sure you load the package with the MultinormalDistribution:
Code:
Needs["MultivariateStatistics`"]
Then turn your code into a function:
Code:
f[x_, c_] :=  NIntegrate[PDF[MultinormalDistribution[{5, 6}, {{1, 1}, {1, 2}}], {x1,
    x2}], {x1, x, c}, {x2, x, c}]
Now you say that you want to evaluate this repeatedly for different values of x, you could use a table:
Code:
Table[f[x,20],{x,1,10,0.1}]
Cool, thanks guys! I've used your suggestions and I think I've got it now, just need to test the result a bit more. Anyway, cheers for the help!
