Calculating Internal Energy Change in a Gas Under Constant Pressure
A gas is compressed at a constant pressure of 0.639 atm from 5.41 L to 2.3 L, with 470 J of energy leaving the gas by heat. The work done on the gas was calculated as approximately 201.31 J, which was confirmed correct. However, the initial calculation for the change in internal energy (ΔU) was incorrect due to using the wrong heat value of 407 J instead of the correct 470 J. With the correct heat value, the change in internal energy is -268.69 J. This highlights the importance of accuracy in values when performing thermodynamic calculations.
duds1234
Hello, this is my first post, so I apologize in advance if it's not quite up to par.
A gas is compressed at a constant pressure of 0.639 atm from 5.41 L to 2.3 L. In the process, 470 J of energy leaves the gas by heat.
a) What is the work done on the gas (J)?
b) What is the change in its internal energy(J)?
a) ##W=-PΔV##
b) ##ΔU=Q+W##
a)
##P = 0.639atm {\frac{1Pa}{9.872*10^-6atm}} = 64728.52512Pa##
##ΔV = V_f - V_i = 2.3L - 5.41L = -3.11L {\frac{1*10^{-3}m^3}{1L}} = -0.00311m^3##
##W = -P ΔV = -6.4728.52512Pa * -0.00311m^3 = 201.3057131J##
I submitted my answer to part a and it was correct. Part b is what I need help with. I believe that I am doing it correctly, but my answer is returned as incorrect. My incorrect work and answer appears below.
b)
##ΔU = Q + W = -407J + 201.3057131J = -205.6942869J##
Any insight into why my work/answer for part b is incorrect would be greatly appreciated!
If your answer to part a is correct, then I can't see what's wrong with your answer to part b (see EDIT)
Is this a multi choice question that is automatically assessed?
EDIT: Just noticed that in the question statement you say that 470J of energy leaves, but in the calculation for part b you use the figure 407J
Unfortunately, this isn't a multiple choice question. I have to submit my answers electronically and a computer grades them. I have confirmation that part a is correct and that my answer for b is incorrect.
Ok. Can you confirm which value of heat leaving the gas is correct: 407 J or 470 J
Likes 1 person
It is 470, thus this would be my error in part b. Thank you very much for helping me find my silly mistake. The correct answer would be -268.6942869J.
You're welcome. It happens to everyone now and then!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
