Calculating Kinetic Energy for a Swinging Wrecking Ball
  • Thread starter Thread starter Zeitgeist
    Energy
To calculate the potential energy of a 315kg wrecking ball at a 30º angle from the vertical, one must determine the height it has been raised from its lowest position. The potential energy (PE) can be calculated using the formula PE = mgh, where 'm' is mass, 'g' is the acceleration due to gravity, and 'h' is the height. When the wrecking ball swings back to the vertical position, all potential energy converts to kinetic energy (KE), meaning KE = PE. The kinetic energy can then be calculated using the formula KE = ½ mv², allowing for the determination of the wrecking ball's speed as it returns to the vertical. Understanding the conservation of energy principle is key to solving this problem.
Zeitgeist
A wrecking ball, with mass of 315kg, hangs from a crane on 10.0m of cable. If the crane swings the wrecking ball so that the angle that the cable makes with the vertical is 30.0º, what is the potential energy of the ball in relation to its lowest positio? What will be the kinetic energy of the wrecking ball when it falls back to the vertical position? What will be the speed of the wrecking ball?
I have no problem finiding the potential energy, but I don't know how to calculate the kinetic energy. and i know EK = ½ mv², but i don't know how to use it here. What should I do?
In the system as you describe it, there is no loss of energy, so any potential energy is going to be converted completely into kinetic energy.
In other words, KE = PE!
Thanx alot
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
