Calculating Maclaurin Series for $\frac{1}{1+cos^2(x)}$
How can I calculate it for \frac{1}{1+cos^2(x)} by using the fact that \frac{1}{1+x^2} = 1 - x^2 + x^4 - ...?
Given in the problem.
I tried letting u = cos(x), then
\frac{1}{1+cos^2(x)} = \frac{1}{1+u^2} = 1 - u^2 + u^4 - ... = 1 - cos^2(x) + cos^4(x) - ...
But I don't think this is right because the first term should be 0.5, not 1... and I don't see how a -0.5 might pop out of this series of cos terms...and even if it somehow does, I think this question is not meant to be that difficult...
The answer I am trying to get is \frac{1}{2} + \frac{1}{4}x^2 + ...
Any ideas?
Thanks
Use cos(x)=1-x^2/2!+x^4/4!-... to express the first few terms of the series for 1+cos(x)^2. Then, sure, use your geometric series. Feel free to drop terms that you know won't be important.
I don't follow, could you spell it out a bit more?
So cos^2(x) = 1-x^2+\frac{1}{3}x^4-...
Now what?
Thanks
Alright. So now you've got 1/(1+1-x^2+x^4/3+...). That's 1/(2-x^2/+x^4/3...). Write it as (1/2)*1/(1-(x^2/2-x^4/6...)). Now use 1/(1-a)=1+a+a^2+... with a=x^2/2-x^4/6+... If you only want a quadratic approximation then you didn't need to keep the x^4 stuff, right?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
