Calculating Magnetic Field Strength for a Simple Bar Magnet
  • Thread starter Thread starter Cheney
    Magnetism
To calculate the magnetic field strength of a simple bar magnet at a specific point on a plane, one must consider that there is no straightforward analytical solution available. The strength of the magnet cannot be determined solely by its dimensions and material properties. A suggested approach is to refer to Jackson's book, which provides equations for the field of a homogenously magnetized sphere as a potential approximation. The complexity of the problem indicates that further exploration and study may be necessary for accurate calculations. Additional questions may arise as the problem is examined more closely.
Cheney
If I have a simple bar magnet which is say 'w' x 'h' metres in dimension placed on a plane, say at cartesian coordinates (xM, yM), how can I work out the magnetic field strength at some arbitary point (x, y) also on that plane.
I've searched the internet but can only find equations to do with electomagnets or magnetism due to electic current. Nothing for a plane old chunk of iron.
I just need the equations, you can define the properties of the magnet such as how strong it is.
Thanks.
The strength of a magnet is not defined by just its size and composition.
- Warren
It's not a trivial problem even though it looks like one. There's no analytical solution that I know of.
You can find the eqs. for the field of a homogenously magnetized sphere in Jackson's book (section 5.10), that might do as an approximation.
Thanks arcnets, I will check out the book. After looking at the problem some more I agree that it is far from trivial.
I'll post if I have any more questions.
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
