Calculating Main Sequence Lifetime.
  • Thread starter Thread starter adwodon
    Lifetime Sequence
To calculate the main sequence lifetime of a 10-M☉ star with a luminosity of 10^4 L☉ and 10% mass conversion from hydrogen to helium, the formula tms ≈ M/L is suggested. The user attempted to apply this formula but found the resulting lifetime of approximately 5 years to be implausibly short. They also calculated the total energy from the mass conversion using E=mc^2, arriving at a similar conclusion. The discussion highlights confusion over the application of the formula and the interpretation of the results. Clarification on the expected lifetime for such a star is sought, indicating a need for further understanding of stellar evolution.
adwodon
1. Calculate the main sequence lifetime in years of a 10-M\odot star if it has luminosity of 104L\odot and 10% of its mass will be converted from hydrogen to helium in the core. What will the end state of this star be?
Ok so I wasn't really sure what to put for working here as I have no idea where to begin, I've been searching around for a forumla or something to calculate the lifetime but my lecturers notes are very vague and not helpful at all and numerous different google searches haven't helped in giving me a straight answer.
I found this formula somewhere but it doesn't make sense to me:
tms\approx\frac{M}{L}
Its part of a larger question involving the Hertzsprung Russell diagram which I've done however this bit I am totally stumped, if any of you guys could point me in the right direction or explain it to me i'd really appreciate it.
Oh and I should point out this is from a past paper, the only relevant information I could imagine is given to help on the front of the paper is (excluding the standards like Planck / speed of light etc):
Solar mass: 2x1030kg
Solar Bolometric Luminosity: 3.9x1026W
Ok so I used E=mc^2 and got the total energy of the converted material as 6x10^38J
Which would sustain that luminosity for 5 years...
Thats roughly the same answer I got from the equation in my original post but I thought it was wrong because 5 years seems waaaaay too short.
Is that a plausible answer?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
