Calculating Mass of Little Sister Using Newton's Second Law
To calculate the mass of the little sister being pulled on a sled, the equation F = (m1 + m2) * a is used, where F is the force, m1 is the mass of the sled, and a is the acceleration. Given a force of 110 N, an acceleration of 2.5 m/s², and a sled mass of 7 kg, the equation simplifies to m2 = (F/a) - m1. This results in the correct mass of the little sister being 37 kg. The initial miscalculation arose from incorrect application of the formula, but the correct steps yield the desired result. Understanding the relationship between force, mass, and acceleration is key to solving such problems.
Propaganda777
You are pulling your little sister on her sled acroos an icy(frictionless) surface. When you exert a constant horizontal force of 110 N, the sled has an acceleration of 2.5 m/s^2. If the sled has a mass of 7 kg, what is the mass of your little sister?
Heres how I attempted it:
F=110N
A=2.5 m/s^2
M1= 7kg
M2= ?
F=(M1+M2) A
M2= 41.2 kg
The answer is 37 kg, but I can't figure out how to arrive at this mass. Can anyone help me?
Propaganda777 said:
F=(M1+M2) A
Since you know F and A, you can solve for M1 + M2. Then just subtract out M1.
I did, but it comes out to a wrong answer:
F= (m1+m2)a
m2=(F-m1)/a
m2=41.2kg
The answer should be 37 kg, right?
F= (m1+m2)a
m2=(F-m1)/a
That last step doesn't follow. Do this:
F = (m1 + m2)a
F/a = m1 + m2
What's that equal?
hey it works, thanks you:)
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
