Calculating masses of 2 objects pushing off of one another
  • Thread starter Thread starter Patra
The problem involves two ice dancers, Boris and Natasha, with a combined mass of 136 kg, who push off from each other, moving at different speeds. The momentum conservation equation is applied, where the total momentum before and after they push apart must remain equal. By setting up equations for their masses and using elimination, the individual masses are calculated to be approximately 77.71 kg for Natasha and 58.29 kg for Boris. The solution checks out as their momenta are nearly equal, confirming the calculations. This demonstrates the application of momentum conservation in an inelastic collision scenario.
Patra
Two ice dancers, Boris and Natasha, have a combined mass of 136kg. They embrace and push apart from each other: Boris moving at 0.90m/s and Natasha moving at 1.2m/s in the opposite direction. Find their individual masses.
p=mv
It seems so stunningly simple, yet I am at a loss as to how to attempt it without having a time variable or knowing the mass of one of the skaters.
use the equation (m1+m2)vf=mv1+mv2, this is an inelastic collision problem. Maybe that will help a little more than p=mv
Thanks, so does that mean it should be something along the lines of (m1+m2)vf=(136kg)(0.90m/s)+(136kg)(1.2m/s)? Should I be using substitution at some point during this problem?
no, both ice dancers start together, then push a part from each other
(m1 + m2)v just equals the momentum of the two dancers as a whole because they both initially start out together.
so the only two unknown variables are m1 and m2
(136 kg) * 0 m/s = m1 (1.2 m/s) + m2 ( -.9 m/s)
0 = 1.2m + -.9 m Keep in mind they are separate variables
You also have m1 + m2 = 136.
So put those equations on top of each other and i like to use elimination. Here is the work:
1.2m -.9 m = 0
-1.2(m1 + m2 = 136)
Which gives you
1.2 m -.9 m =0
-1.2 m -1.2 m = -163.2
Which simplifies to
-2.1 m = -163.2 (we are solving for m2, i always made m2 second in every equation)
m2 = 77.71 kg
m1= 136- 77.71= 58.29 kg
You can check it and you get there respective momentums which should be equal to be 69.948= -69.939, so its close enough
* And yeah my method is a little different from the other persons. I did this chapter a while ago so i kind of forgot that stuff..lol
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
