Calculating Minimum Speed for Ballistic Pendulum with Attached Mass
The discussion focuses on calculating the minimum speed of a wad of putty required to make a suspended stick rise to a horizontal position after a collision. The problem involves applying conservation of momentum and energy principles, with the angular momentum of the putty being a key factor. The moment of inertia is calculated using the formula I = (1/3)M*d^2 + m*r^2. The user attempts to solve the equations but arrives at an incorrect speed of 33.39 m/s, indicating a misunderstanding in the application of the center of mass and height in the energy conservation equation. The discussion highlights the complexities of the calculations involved in this physics problem.
ArticMage
A uniform stick d = 1 m long with a total mass of 249 g is suspended vertically from a frictionless pivot at its top end. A wad of putty of mass 29 g is moving horizontally with speed v. It strikes and sticks to the stick at a distance 0.75 m from the pivot.
What is the minimum speed of the putty such that the stick, with the putty stuck to it, will rise to the horizontal position?
L=m*v*r
L=I*w
.5*I*w^2=m*g*h
Conservation of momentum applies so first I have the angular momentum of just the putty with respect to the axis of the rod.
L=m*v*r
then just after the collision the rod has a angular momentum of
L=I*w
this gives me m*v*r/I=w which I use in a bit
The I = (1/3)M*d^2+m*r^2
Next, after the collision i use conservation of energy.
.5*I*w^2=(M+m)*g*h
h=cm=(M*d+m*r)/(M+m)
solving the above for w i get sqrt((2*g(M*d+m*r)/I)
now back to w=m*v*r/I gets me I/(m*r)*sqrt((2*g(M*d+m*r)/I) = v
this gets me 33.39 m/s which is wrong.
I tried without the cm stuff and just had h= 1 but that gets just about the same answer just a littler higher and also wrong.
The center of mass of the stick is at d/2, not d. :smile:
argh why is it always something so simple.
thanks for the help though.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
