Calculating Moment Capacity of A36 steel plate
To calculate the maximum moment capacity of an 8" A36 steel plate used as a beam, the nominal moment strength can be determined using the AISC Steel Construction Manual. The equation for deflection is correctly noted as Fb*L^3/(48*E*I), but the nominal flexural strength, Mn, must consider yielding and lateral-torsional buckling. For allowable strength design (ASD), divide the calculated moment by 1.67. It's essential to identify whether the plate is bending about its major or minor axis, as this affects the calculations. Always consult a licensed Civil/Structural professional engineer for safety-critical applications.
dtbernar
I am using an 8" steel plate as a beam that will undergo moment forces and deflections. I am not sure how to calculate the maximum moment capacity of a plate like this. I think that the deflection would = Fb*L^3/(48*E*I). Does this look correct?
I know how to calculate the max moment in the beam, but I need to know the nominal moment strength. Does anyone know the equation to do this? I believe that I will have to divide this by 1.67 for ASD allowable strength.
Do not use the information below if you are designing/building something that could impact public works or put people in danger. Stop immediately and hire/contract a licensed Civil/Structural professional engineer in your area:
Depending on your application, here is what is used for buildings and other structures:
The allowable flexural strength for Rectangular Bars (Mn/Ωb for ASD) can be determined by AISC Steel Construction Manual Thirteenth Edition: Chapter F Design of Members for Flexure if it satisfies the assumptions/requirements in the general provisions (I'll let your look those up.) Section F1 (general provisions) sets Ωb=1.67 for ASD. Section F11 governs nominal flexural strengths, Mn, for rectangular bars bent about either geometric axis. The two limit states are yielding and lateral-torsional buckling. The lower of the two calculated Mn values should be used in your calculation of allowable flexural strength.
These allowable flexural strengths are intended to be used with the load cases generated by the applicable building code, and when that is not present, use the applicable ASCE07 load combinations.
dtbernar: Is your plate bending about its minor axis or major axis? If it is bending about its major axis, see post 2. If your plate is subjected only to static loading, in a building, and is bending about its minor axis, then you would want to ensure the applied moment, M, does not exceed 0.25*b*(t^2)*Sty/1.67, where b = plate width (mm), t = plate thickness (mm), and, for your material, Sty = 250 MPa.
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
32K
16K
