Calculating Net Force and Direction of Barge Movement with Vector and Forces"
  • Thread starter Thread starter Natalie7268
    Forces Vector
To calculate the net force on the barge, the individual force vectors from the three tugboats must be resolved into their x and y components. Tugboat A exerts a force of 50N at 30 degrees north of east, Tugboat B pulls with 80N directly south, and Tugboat C applies 15N at 30 degrees west of north. The correct approach involves summing these components to determine the resultant vector's magnitude and direction. The final answer should specify the net force's direction in degrees relative to a compass direction. Proper vector addition is essential for accurate results.
Natalie7268
three tugboats are pulling on a very small barge in the harbor. Tugboat A is pulling with a 50N force in a direction 30 degrees north of east. Tugboat B is pulling with a force of 80N in a direction directly south, and tugboat C is pulling with a force of 15N in a direction 30 degrees west of north.
What is the net force applied to the barge by the tugboats and in what direction with it move?
I did not know an equation to use my teacher didn't use one he drew an axis and I can't figure out a better way to do it I'm so confused!
I did 50 - 15 Newtons and got 35 and then I took 35 from 80 and got 45 Newtons in the south east direction but that's wrong
You need to find the x and y components of all three of those force vectors. Then you will be able to find the magnitude and direction of the resultant vector. Do you know how to find the individual components?
What KrazySocoKid said - remember: force is a vector so you need the vector sum of the forces.
You can do this by components or geometrically: head-to-tail.
Your answer should be a number of degrees from some compass direction.
i.e. due SE is 45deg south of east.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
