Undergrad Calculating power output on a spin bike
To calculate power output on a home spin bike lacking sensors, one can use the bike's specifications, including an 18kg flywheel and a cadence sensor. The approach involves pedaling at a consistent cadence and measuring how long it takes for the flywheel to stop, which helps determine the resistance from the magnets. It's important to accurately calculate the Moment of Inertia of the flywheel, considering its shape, and to temporarily remove the magnet to isolate the effects of friction. This method assumes a linear relationship between the resistance and the angular velocity of the flywheel. Overall, this dynamic calculation can provide insights into power output based on cadence.
SpinnerDude
So...I have a home spin bike which unfortunately lacks the sensors of some of the more expensive models. What I'm trying to do is work out if I can dynamically calculate my power output.
The spin bike itself has:
- An 18kg flywheel of radius 30cm
- Direct drive between the crank and the flywheel (one turn of the crank = six turns of the flywheel)
- Resistance is provided by a magnet that is lowered onto the flywheel rim
- An additional cadence sensor on one of the crank arms
It feels like I should be able to map the resistance settings on the bike, such that the power output can be calculated based on the cadence alone.
My first thoughts are around pedalling at a set cadence and seeing how long the flywheel takes to stop, and from there working out the resistance produced by the magnets (which I'm currently assuming to have a linear relationship with the angular velocity of the flywheel)
Any advice/comments?
That sounds like a good plan to me. You will need to accurately calculate the Moment of Inertia of the flywheel (is it a perfect disk shape, or does it have a flange like lifting weights?), and you should remove the magnet temporarily so you can see how long it takes to spin down with no explicit damping/drag (to be able to separate the friction terms of the damping).
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
26K
  • · Replies 22 ·
  • · Replies 16 ·
11K
9K
