Calculating Pull Force on Weights Connected by Cords
  • Thread starter Thread starter Motorboar
    Force
The discussion revolves around calculating the pull force on a series of weights connected by cords, given an upward acceleration of 4.00 m/s². The weights have masses of 5 kg, 10 kg, 15 kg, and 20 kg, and the pull force P is being questioned. The initial calculation using F = ma resulted in a pull force of 552 N, which does not match the provided answer options. Participants suggest that the logic in the equations is correct, but there may have been an error in the mass calculations. The user ultimately realizes they miscalculated the total mass.
Motorboar
A series of weights connected by very light cords are given an upward acceleration of 4.00 m/s2 by a pull P, as shown in Fig. 5.3.( a verticle strand of 4 balls with mass 5,10,15,and 20 kg with the pull at the top) A, B, and C are the tensions in the connecting cords.
the pull P is closest to:
290 N
690 N
50 N
200 N
490 N
F= ma
treating the weights as one mass
Pull-mg=ma
pull=m(a+g)
= 552
Which is not one of the answers. What is the error in my logic?
Likes Bassim Kiani
Pull-mg=ma
pull=m(a+g)
= 552
I'm don't see an error in your logic (if I'm interpreting your description of the figure correctly). :approve: Maybe there's an error in your calculations? :rolleyes: What did you use for m and g?
[Edit: In other words, your equations seem fine. But I don't know why you ended up with 552]
added the masses wrong xD Thank you.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
