Calculating radius of gyration of plane figure about x-axis
Evari5te
K.A Stroud Engineering Mathematics 8th edition Kindle version Chapter 2.21 Further problems #1
A plane figure is enclosed by the x-axis and the curve ##y=a\sin x## between ##x=0## and ##x=\pi##
Show that the radius of gyration ##k##, of the figure about the x-axis is given by ##\frac{a.\sqrt[]{2}}{3}##
Radius of gyration, ##k = \sqrt[]{\left(\frac{I}{A}\right)}## where
##I## is the Area Moment of Inertia given by integrating the square of the distance ##y## from the x-axis to each infinitesimal element of area, ##dA## of the figure, multiplied by the area element itself.
##I=\int_0^\pi y^2dA##
##\therefore I = \int_0^\pi a^2 \sin^2 x dA##
##dA = y.dx = a \sin x dx##
##\therefore I = \int_0^\pi a^3 \sin^3 x dx = a^3 \int_0^\pi \sin^2 x.\sin x dx##
The closest I can get is ##k=\frac{\sqrt{2}a}{\sqrt{3}}## as follows:
Let
##u=\sin^2x##, ##\therefore \frac{du}{dx} = 2\sin x \cos x##
##\frac{dv}{dx}=\sin x##
##\therefore v = \int \sin x dx =-\cos x +C##
Integrating by parts
##I=a^3 \left\{uv - \int_0^\pi v\frac{du}{dx} dx \right\} ##
##I = a^3 \left\{ \left[\sin^2 x \left(- \cos x \right) \right]_0^\pi - \int_0^\pi \left(- \cos x \right).2\cos x.\sin x dx \right\} ##
Because ##\sin 0=0## and ##\sin \pi =0##, ##\left[\sin^2 x \left(- \cos x \right) \right]_0^\pi = 0 - 0##
leaving
##I = a^3 \left\{ - \int_0^\pi \left(- \cos x \right).2\cos x.\sin x dx \right\} ##
Taking the ##-1## multiplier from the ##\left(- \cos x \right)## term and ##2## multipler from the ##2\cos x.\sin x## term outside of the integral (so negating the minus) gives
##I=+2a^3 \int_0^\pi \left(\cos x \right).\cos x.\sin x dx = +2a^3 \int_0^\pi \cos^2 x.\sin x dx##
Using the identity ##\cos^2 x = 1 - \sin^2 x##
##I =2a^3 \int_0^\pi \left(1-\sin^2 x \right).\sin x dx ##
##I=2a^3 \left\{ \int_0^\pi \sin x dx - \int_0^\pi \sin^3 x dx \right\}##
##I= 2a^3 \left[-\cos x \right]_0^\pi - 2a^3 \int_0^\pi \sin^3 x dx ##
The term ##a^3 \int_0^\pi \sin^3 x dx## on the right hand side is now the same as the original integral so
##I = 2a^3\left[-\cos x \right]_0^\pi - 2I##
##\therefore 3I = 2a^3\left[-\cos x \right]_0^\pi##
##\cos \pi = -1 \therefore -\cos \pi = 1 ##
##\cos 0 = 1 \therefore -\cos 0 = -1##
##\therefore 3I = 2a^3\left[1 - \left(-1\right) \right] = 2a^3\left(2\right) = 4a^3##
##\therefore I = \frac{4a^3}{3}##
##A## is the area of the figure,
##A=\int_0^\pi a \sin x dx = a\left[-cos x\right]_0^\pi = 2a##
## k=\sqrt[]{\frac{I}{A}}=\sqrt{\frac{4a^3}{3.(2a)}} = \sqrt{\frac{2a^2}{3}}=\frac{\sqrt{2}a}{\sqrt{3}}##
Am I wrong or is there a typo in the book?
I'm getting the same answer as the book. I disagree with your ##I##
I agree with the integral you set up but I think you are going the wrong way about evaluating it. That is to say making it too complex/long and prone to errors. Try this
##I = \int_{0}^{\pi} \frac{a^3}{3} \sin^3 x \, dx = \int_{0}^{\pi} \frac{a^3}{3} \left(1 - \cos^2 x \right) \sin x \, dx##
make ##u = \cos x## and do you ##u##-substitution and see if you get
##I = \frac{4a^3}{9}##
Typo in last post fixed
Thanks PhDeezNutz. There is a key difference in your initial integral to mine which is the ##\frac{1}{3}## multiplier.
This entirely accounts for the mistake in my attempt, at it remains a constant multiplier along with the ##a^3## throughout and outside of the work resolving the integral.
This results in ##3x3=9## in the last denominator for ##I##, which then square roots to 3 in the ##k=\sqrt{\frac{I}{A}}## calc. Since I didn't include it in my initial integral I end up with ##\sqrt{3}## in my final answer for ##k##.
It's not immediately clear to me why we divide by 3 if rotating the figure around the x-axis instead of the y axis. Perhaps I'm mixing examples using area strips with those using infinitesimal area elements, and getting it wrong at the very first stage.
Is ##dA=dy.dx## rather than ##dA =y.dx## as I initially set out in the relevant equations?
Then would
##I = \int_0^\pi y^2 dA = \int_0^\pi y^2 dy.dx##
and the ##y^2.dy## be integrated as a first step to give the ##\frac{y^3}{3}## term?
At least this gives the right answer, but I'm not very confident my rationale is correct...
I believe your rationale is correct (it's the one I used)
##I = \int_{x=0}^{\pi} \int_{y=0}^{a \sin x} y^2 \, dy dx##
##I = \int_{x=0}^{\pi} \left.\frac{y^3}{3} \right|_{y=0}^{a\sin x} \, dx##
etc....That ##\frac{1}{3}## turns to ##\frac{1}{9}## later when you integrate another "##u^2##" as outlined in post 2
What is wrong is that your differential element is incorrect for the application of the definition. It needs to be horizontal here such that the element has a singular value for ##y## at each differential strip. Slice it parallel to ##x## axis if you are going to try that type of maneuvering (it will be probably be a headache in comparison to the double integration).
in the left, if you take ##y## at the centroid of the element ##y/2##, you'll notice you get a factor of a ##\frac{1}{4} \int y^2 dA##, so that doesn't fix your problem with ##I## if its indeed to be a ##\frac{1}{3}## of your result.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
