Calculating Relative Motion Using Time and Distance Equations
To solve the problem of calculating the ratio of the man's running speed to the sidewalk's speed, the key is to recognize that he travels the same distance in both directions. By setting up the equations for velocity as V(with) = length/2.5 and V(against) = length/8, one can express the distance traveled in both cases. Since the distances are equal, equating the two expressions allows for the determination of the ratio of speeds. The solution hinges on eliminating the unknown length of the sidewalk by using the equality of distances. Ultimately, this approach will yield the desired ratio of the man's running speed to the sidewalk's speed.
uberbandgeek6
A suspicious-looking man runs as fast as he can along a moving sidewalk from one end to the other, taking 2.50 s. Then security agents appear and the man runs as fast as he can back along the sidewalk to his starting point, taking 8.00 s. What is the ratio of the man's running speed to the sidewalk's speed? (running speed / sidewalk speed)
Thanks
Where is your attempt at the solution?
I'm not sure how to go about it. I set up the velocities as V(with)=length/2.5 and V(against)=length/8, but I'm not sure what to do from there.
How do I work around the fact that i don't know the length of the sidewalk?
You know that both times he travels the same distance. What you need to do is find an expression that would give you the distance for run 1 and run 2. You can then equate them because you know the distance should be the same and you should be able to find the answer from there.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
