Calculating Resultant Force from Two Forces at a Point
  • Thread starter Thread starter treverd
    Forces Point
To calculate the resultant force from two forces acting at a point, the x-component and y-component of each force must be determined. The x-component of F1 should be calculated using the formula F1*cos(180-65) and the x-component of F2 using F2*cos(180+52.3). The y-component for F1 is found with F1*sin(180-65) and for F2 with F2*sin(180+52.3). The overall resultant force is then calculated by summing the x and y components and applying the Pythagorean theorem. Accurate calculation of both components is essential for determining the magnitude of the resultant force.
treverd
Two forces, F1 and F2, act at a point. The magnitude of F1 is 9.80 , and its direction is an angle 65.0 above the x-axis in the second quadrant. The magnitude of F2 is 5.00 , and its direction is an angle 52.3 below the x-axis in the third quadrant.
What is the x-component of the resultant force?
What is the y-component of the resultant force?
What is the magnitude of the resultant force?
Fcos(\vartheta) for X-component
Fsin(\vartheta) for y-component
\sqrt{X-comp^{}2/y-comp^{}2}
I take
9.8*Cos(180-65) for X-component but that's wrong
what else should I try.
Thanks alot.
Theres 2 forces, why did you only calculate the x-component of the one force. It wants the sum of the x components of both forces.
This is just what I started on. If I don't get this part right then I won't be able to get the rest right.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
