Calculating RH & Rp in an Open Dust-Filled Universe
  • Thread starter Thread starter sltungle
    Universe
The discussion focuses on calculating the radius of the Hubble sphere (RH) and the radius of the particle horizon (Rp) in an open, dust-filled universe using the Friedmann equations. The user is attempting to determine RH but is confused about whether to treat the scale factor a as a function of time or space. They plan to compare RH and Rp by plotting both functions to check for any intersection, but need clarification on the correct approach to derive RH first. The user expresses uncertainty about the persistence of certain terms in their equations and suggests the possibility of needing a 3D graph for analysis. The inquiry highlights the complexities involved in cosmological calculations and the need for further assistance.
sltungle
1. Using the parametric solution of the Friedmann equations for a open, dust-filled universe
i) Calculate the radius of the Hubble sphere (RH) for a 'dust filled' open universe.
ii) Compare this with the radius of the particle horizon (Rp) for the same universe and determine if there exists a time when RH = Rp
For part (i) I've used the fact that,
to attempt to determine RH.
Given that a is not in terms of t and the equations can't be rearranged to give a in terms of t I've opted to use the chain rule to determine a'(t)
This is the correct way to proceed with the question (according to my lecturer).
Here's where I get confused though. Because t is already a function of x, do I simply use a(x) as my a(t)? That being, is the 't' in a(t) already accounted for by the fact that a(t) is actually (a(t(x))), or do I have to take da/dt, 'multiply' both sides of my equation by dt (don't get angry at me, pure mathematicians), and then integrate (where dt is actually dt(x)) to find a(t)?
To answer part (ii) I intended to find the equation for the particle horizon and then plot both functions (RH and Rp) on the same axes and check to see if there was ever an intercept, but I need to get RH correct in order to do that, so I'm not going to jump ahead of myself just yet. However, that said, just from the looks of things I don't think all of my Ω0 terms are going to drop out of the equation, so I'm not sure how I'm going to approach this if they stick around. I guess I might need to plot a 3D graph with x values, omega values, and respective RH and Rp values.
I apologise if this is a bit convoluted. I intended to use latex, but I'm not sure how to get it working on here.
Nobody? This question is really bugging me. I'd really appreciate the help.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
