Calculating Rollercoaster Energy and Designing for Conservation
  • Thread starter Thread starter BlueCardBird
    Rollercoaster
The discussion revolves around designing a rollercoaster for a homework assignment, focusing on energy conservation while incorporating a loop, collision, and two hills. The student is confused about the calculations needed for the loop's radius and the spring constant, seeking guidance on how to start. Key points include the importance of ensuring the marble maintains sufficient speed through the loop and the need to minimize energy loss during the collision. Participants suggest working backward from the end of the track and clarify the calculations related to the forces involved in the loop. The conversation emphasizes understanding the mechanics of energy conservation throughout the rollercoaster design.
BlueCardBird
So there's an assignment that I must complete which is to build a rollercoaster. The main problem is during the blueprint stage, I'm extremely confused with the calculations. This roller coaster must have one loop, a collision and 2 hills, the goal is the conserve the most energy as a object (marble) going through the circuit. In addition the rollercoaster must be activated by a spring. What I had in mind was to have one hill, a collision followed by another hill and finally the loop. Further more, the height of the first hill may be at most 30.cm above the finishing height. The starting height may be up to 15 cm above the bottom.
Ek=1/2mv^2
Eg=mgh
Fc=m(v^2/r)
Es=1/2kx^2
To be honest I just need to find a radius of the loop and k value for the spring but I have no idea where to start calculation, it seems like always one variable is missing. Can anyone give me a start?
What you need from the spring is energy, so it could be a high k or a long displacement.
What springs are available?
Need more info re the collision. Are there two marbles, the first impeling a second, and only the second making it to the end? If not, what is the collision?
For the loop, there is a minimum speed to ensure it stays in contact all the way round. Do you know how to calculate that?
Well for the collision the second marble must finish the track keep in mind that the goal is to have the most mechanical energy conserved from beginning to end. The compression of the spring and constant are decided by me but i don't have enough information to calculate it i don't know whether i should set a radius and calculate the rest from there or to find a spring and calculate the radius that way.
So how would you arrange the collision so as to minimise loss of energy?
If you can find a spring to meet whatever requirement, you could start from the end and work backwards. You didn not answer my question about making it around the loop.
The spring has no requirements and as for the loop I am not aware of that, to my knowledge its just Fc=m(v^2/r) and you can find the radius that way.
So the minimum speed at top of loop is?
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
