Calculating Rotational Energy of Disk After Forces Applied
A uniform disk with a mass of 9.32 kg and a radius of 1.37 m is subjected to three forces, each of 340 N, applied in different directions. The problem requires calculating the rotational energy of the disk after 1.5 seconds of force application, starting from rest. The relevant equations include the moment of inertia, torque, angular acceleration, and the formula for rotational energy. The user confirms their approach by substituting values into the energy equation after determining angular velocity. The calculations provided are deemed correct by another participant in the discussion.
ctwokay
A uniform disk with mass m = 9.32 kg and radius R = 1.37 m lies in the x-y plane and centered at the origin. Three forces act in the +y-direction on the disk: 1) a force 340 N at the edge of the disk on the +x-axis, 2) a force 340 N at the edge of the disk on the –y-axis, and 3) a force 340 N acts at the edge of the disk at an angle θ = 30° above the –x-axis.
Q: If the disk starts from rest, what is the rotational energy of the disk after the forces have been applied for t = 1.5 s?
I=1/2*mR^2
τ=I*alpha
ω=ωi+alpha*t
E=1/2*I*ω^2
I just want to check whether my working is correct or not.
I use ω=ωi+alpha*t which ωi is zero,then i sub in the values to E=1/2*I*ω^2 to find the rotational energy.
Please help me check my workings is it right?
Thank you.
hi ctwokay! :smile:
(have an alpha: α and try using the X2 and X2 buttons just above the Reply box :wink:)
ctwokay said:
I=1/2*mR^2
τ=I*alpha
ω=ωi+alpha*t
E=1/2*I*ω^2
yes, that's fine! :smile:
thank you very much
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
