Calculating Spacetime Intervals for Simultaneous Events
In summary, the conversation discusses the concept of simultaneity and the use of Lorentz transformations to find velocity. The first event is found to have a spacelike invariant interval, leading to a velocity of half the speed of light. The second event is also found to have a spacelike invariant interval, with the same velocity but opposite sign. The third event is found to have a timelike invariant interval, indicating that the velocity cannot be found using the same method as the first two events. Ultimately, it is concluded that no velocity can be found for this third event without violating the speed of light.
milkism
118
Analyse of two events with the use of invariant intervals
I= -c²t² + d²
Exercise:
My solutions:
  1. For events to be simultaneous, the invariant interval must be bigger than zero (spacelike). I got $$I = -c^2 \Delta t^2 + \Delta x^2 + \Delta y^2 + \Delta z^2 = -(0-1)^2 + (0-2)^2 + (0-0)^2 + (0-0)^2 = -1 + 4 = 3 >0$$. Which is indeed greater than zero, to find the velocity, I will use the first Lorentz-transformation formula with four vectors $$\overline{x}^0 = \gamma \left( x^0 - \beta x^1 \right) = \Delta (c\overline{t}) = \gamma (\Delta (ct) - \beta (\Delta x))$$, we want $$\Delta \overline{t} = 0$$. We get: $$\Delta (ct) = \beta (\Delta x) = \frac{0-1}{0-2} = \frac{v}{c} = v = \frac{c}{2}$$. Where $$\beta = \frac{v}{c}$$.
  2. The new spacetime coordinates for second event will be (-1,2,0,0), the invariant interval doesn't change, meaning it's still spacelike, so the velocity will be the same but opposite sign.
  3. No, for two events to occur at the same point (place) the invariant interval must be negative (timelike), which isn't.
So you're claiming ##\Delta (ct) = \frac{c}{2}## so ##-1 = 1.5\times 10^8~\rm m/s##? Don't use an equal sign to connect steps.
You may want to rethink this one.
Likes milkism, topsquark, MatinSAR and 1 other person
vela said:
So you're claiming ##\Delta (ct) = \frac{c}{2}## so ##-1 = 1.5\times 10^8~\rm m/s##? Don't use an equal sign to connect steps.You may want to rethink this one.
Are the spacetime coordinates wrong?
##v = \frac c 2## looks right for part (i), but your work seems very muddled to me. For example:
For part (ii) you need to work things out properly. You've effectively just guessed a (wrong) answer.
Likes milkism, topsquark and MatinSAR
PeroK said:
##v = \frac c 2## looks right for part (i), but your work seems very muddled to me. For example:For part (ii) you need to work things out properly. You've effectively just guessed a (wrong) answer.
Well, I'm lost.
You know the coordinates in ##S##. Try using your answer ##\beta = -1/2## and the Lorentz transformation and see what you get for the coordinates in the other frame.
Likes milkism and topsquark
milkism said:
Well, I'm lost.
This problem, IMO, is simply asking you to solve an equation for ##v##. Namely:$$\gamma(1 - 2\frac v c)= -1$$
Likes milkism
Haha, I thought we had to do something with invariant intervals for (ii), thanks! Is my solution for (iii) correct?
Yes. Note that you can prove it in this case by showing that no allowable ##v## would solve the relevant equation.
Likes milkism
Because it would be bigger than the speed of light?
I don't know. Try it!
  • Haha
Likes milkism
