Calculating Speed in Circular Motion: A Roller Coaster Conundrum
To determine the speed of the roller coaster cart at a quarter loop from the highest point, the conservation of energy principle is essential. The cart's potential energy at the highest point converts to kinetic energy as it descends. At the highest point, the cart has both potential energy and kinetic energy, while at the center of the loop, its potential energy decreases, increasing its kinetic energy. By applying the conservation of energy equations, the speed at that point can be calculated. Understanding circular motion and using a free-body diagram can further clarify the forces acting on the cart.
fightboy
A 400kg roller coaster cart travels along the inside of a vertical circular track of radius 10 m. At its highest point it moves at 20 m/s. Friction between the cart and track is negligible.
Find the cart's speed one quarter of a loop later (when it's at the same height as the loop's center).
I know there is radial acceleration due to the change of the velocity vector around the circular path, but how do I know the speed is changing? Also how can I determine what the speed will be at that exact point along the circular path? Any help is appreciated! I'm really confused on how to set up this problem
The tools you can bring to bear are:
1. your understanding of circular motion
2. a free-body diagram
3. conservation of energy
ah ok i forget to apply the conservation of energy equations to this problem, I'll give it a go thanks!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
