- #36
astroscout
- 62
- 4
Thanx Tom. Good to know. We'll see what we can do.
OK, can you do the same with the other one?astroscout said:I was able to use starry night software and astrometry.net to find the star formations and the altitude of Beta Sextantis using the timestamp and location of Paul Smith at the time of the photo.
Timestamp = April 10, 2018 at 1am
Altitude of Beta Sextantis = 22 deg
Location of the camera = Latitude = 54.937806 N Longitude = -112.510886 W
No.astroscout said:Paul has not been able to contact the other photographer yet. Hopefully he will. If he can't, can the info I found be enough to get an approximation?
astroscout said:Please guys...Lets focus on what is needed to calculate the height of the purple arc. If he were to get the angle using stellarium, can we calculate the height or do we need the info from the second photographer?
If it were possible to identify common elements of each, you should be OK.astroscout said:Here is the photo taken by the other photographer, Savoie. Looks like he didn't get the top of the arc like Paul did so I guess we are out of Luck in trying to figure out the height of it. Any Suggestions?
Were you able to get any time/location alt/azimuth and direction info on this one?astroscout said:Here is the photo taken by the other photographer, Savoie. Looks like he didn't get the top of the arc like Paul did so I guess we are out of Luck in trying to figure out the height of it. Any Suggestions?
That makes perfect sense. As I mentioned, I did not actually calculate the height of of STEVE per se, I calculated the height of one of the blobs in the pic. I don't really know what part of the pics are STEVE. They could be tens of kms higher.astroscout said:Paul relayed your calculation of 157.4 Km to her and she says that using their instruments they were close to that result at about 170 Km.
DaveC426913 said:OK, here's what I get:
So, total distance 583.81km (looks like you meant 370 miles).
PIC S (Savoie)
Angle of Polestar = latitude of observer.
So angle of polestar in pic S is 47.71
I picked the top of that group of spikes as a reference point.
It is 82% of the height of the polestar, which would make it an angle of 39.12 degrees (82% of 47.71).
PIC P (Paul Smith)
Angle here is a given of 22 degrees.
I assume here that I have the same reference point as in PIC S - a whopping assumption.
This gives the following geometry:
I used this handy calculator: to arrive at a height of 157.37km
This gives an altitude of that bit of aurora of 157.4km.
As to what that means in relation to the altitude of STEVE, do with it what you will.
