Calculating Stresses for Metal Pole Design in Audio System Installation
In summary, the conversation discusses the design of a metal pole to install horn speakers for a public audio system. The pole will be 10 meters tall with 1.5 meters buried underground and 8.5 meters above ground. The top 2 meters will have 8 horn speakers installed on 4 levels. The pole must withstand wind speeds of 45 m/s at 10 meters above ground. There is a discussion about potential changes to the design for financial reasons and the need for professional help to ensure safety and proper calculations.
Shady Artin
I'm working on a public area audio system where we need to install our horn speakers on big height as per their installation requirements.
We designed a metal pole as described:
Pole consists of two poles: 1) a 7.5 meters height, 10" diameter, 6mm thickness. 1.5 meters are to be buried underground with concrete base, 2) a 4 meters height, 3" diameter, 5mm thickness. 1.5 meters are common with part1 pole and to be attached to it by two hinges with round metal "belts".
Final product should be of 10 meter height, 1.5 meter of them is underground, so it will be 8.5 meters above ground level.
On the top 2 meters of part2 pole, we should install 8 horn speakers on 4 levels (from top of pole: 50cm, 80cm, 110cm, 140cm) each horn weights around 10 Kg each (total of 80 Kg)
Final pole should withstand wind speed: 3 sec. gust speed, 45 m/s (160 km/h) at 10 m above ground
I need to know, how should I calculate the stresses to make sure that the pole will stand till under winds and also we are thinking about making the lower part 6 meters height instead of 7.5 meters and increase the difference in the upper part to be 5.5 meters instead of 4 meters for financial reasons, will that be acceptable??
Attached our initial design for more details.
Thanks in advance for your usual help
  • TEMP PAGA POLE DESIGN.pdf
Thread closed for Moderation...
You seriously go to the Internet to try to get help with calculations like this that involve public safety? Don't you have professional engineers available to do this? Don't you have an insurance company that needs to sign off on the final design and construction? Don't you have city inspectors whose job it is to approve plans like these and do final inspections and sign-offs on the project?
Please get professional help locally, instead of putting the public at risk trying to cut corners on your construction projects getting advice off of the Internet.
Thread will remain closed.
Related to Calculating Stresses for Metal Pole Design in Audio System Installation
1. What materials are commonly used in metal pole design?
There are several materials that are commonly used in metal pole design, including steel, aluminum, and composite materials. The choice of material depends on factors such as strength, weight, and cost.
2. How are metal poles tested for strength and durability?
Metal poles are typically tested using a variety of methods, such as tension and compression tests, bending tests, and fatigue tests. These tests help determine the maximum load a pole can withstand and how it will perform over time.
3. What factors should be considered when designing metal poles for outdoor use?
When designing metal poles for outdoor use, factors such as weather conditions, corrosion resistance, and structural stability must be taken into account. The design should also consider the intended use and load requirements of the pole.
4. What are some common issues that can arise with metal pole design?
Some common issues that can arise with metal pole design include inadequate strength or stability, corrosion and rusting, and poor installation or maintenance. These issues can lead to structural failures and safety hazards.
5. How can metal pole design be optimized for cost-efficiency?
To optimize metal pole design for cost-efficiency, careful consideration must be given to material selection, manufacturing processes, and installation methods. Regular maintenance and inspections can also help extend the lifespan of metal poles and minimize replacement costs.
  • Materials and Chemical Engineering
  • Mechanical Engineering
  • Electrical Engineering
