Calculating tangential velocity of an air parcel circulating a tornado
The discussion centers on calculating the tangential velocity of an air parcel near a tornado, specifically comparing velocities at different distances from the center. The key equation used is v = rω, where ω is the angular velocity, which remains constant regardless of radius. The calculation shows that at 100m from the tornado center, the tangential velocity is 0.5 m/s, slower than at 2000m, which contradicts initial expectations. This is explained by the fact that the inner parcel travels a smaller radius, requiring less speed to maintain its circular path. The analogy of runners on a track illustrates that those on the outer lanes must run faster than those on the inner lanes.
Timebomb3750
If an air parcel 2000m from a tornado center has a tangential velocity of 10 m/s, what is the resultant tangential velocity if the parcel is 100m from the tornado center.
v = rω, where r = radius, and ω = angular velocity
ω = v/r
I understand that the tangential velocity of the air parcel should be much faster as radius drops. But how am I supposed to calculate tangential velocity of it requires the calculation of angular velocity which requires velocity. I'm really lost.
Angular Velocity is not dependant on radius, therefore, it will be the same for each radius. You can find angular velocity with the equation ω = v/r. Use that value to find the tangential velocity at the new radius.
Okay, here's my work.
ω = 10 (m/s)/ 2000m = .005 radians/sec
Then I put that into the tangential velocity question:
v = rω = 100m*.005 radians/sec = .5 m/s
Why is it that the tangential velocity got slower as radius decreased? I thought it was the other way around as I mentioned in my first post.
The tangential velocity is slower near the center of the disk because it doesn't have to circle around as big of a radius as the outside. Imagine running around a circular track... the people on the outside have to run faster to keep up with the people on the inside lanes. This is not true for planets though, because the inner planets are affected by the sun's gravity more and travel faster in the tangential direction to maintain their orbits.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
