Calculating tension in a wire holding beam against wall
The discussion revolves around calculating the tension in a wire supporting a beam with a mass at its end. The user initially approaches the problem using trigonometry, calculating the tension as 400N based on the sine of the angle. However, the correct method involves taking moments about the hinge, leading to the equation T sin(30) * 0.5 = 200 * 0.5. This method accounts for the vertical force at the hinge, which is crucial for accurate calculations. The user acknowledges this clarification and recognizes the importance of considering moments in such problems.
mashedpotato
Hi, this is my first forum post - sorry if I'm in the wrong place, or I've done something wrong!
Here goes: There is a beam of 0.5m length hinged to a wall at a right angle with 200N mass at the end of the beam. This is supported by a wire T at angle 30°. The question asks to find tension in T.
It seems I can answer the question correctly, however, looking at the solutions, I do not understand why an answer was obtained in such a way...
Turning Moment = force x distance.
Ok, so I made the triangle into a trigonometry problem. Opposite = wall, Adjacent = beam and Hypotenuse = Wire / Tension.
Opp = 200N, I want to find Hyp ∴ Hyp = 200 / sin(30) = 400N. This answer is actually correct, but the answers use this as a solution:
T sin(30) x 0.5 = 200 x 0.5
If someone could please help, I would be extremely grateful, as this question has been frustrating me for some time.
mashedpotato.
Ok, sorry for this post but I *think* I've found the solution. Please do correct me if I'm wrong.
So, technically:
Hyp (T or Tension) = 200 / sin(30)
sin(30) * T = 200
But the answer uses: T sin(30) * 0.5 = 200 * 0.5 which is the same as saying sin(30) * T = 200
Thanks & Best Regards,
mashedpotato
That solution is taking moments about the hinge where the beam meets the wall, whereas your method looked at vertical components of forces.
Your method is unsafe because you have effectively assumed there is no vertical force from the hinge. That happens to be true in this case, but if you move the point of attachment of wire to beam to somewhere else along the beam it will not be, and the book method succeeds while yours fails.
Likes David Lewis
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
