Calculating the change of a Wind Turbine's RPM due to Airflow as f(t)
Calculating the change in a wind turbine's RPM due to airflow involves complex mathematical modeling that accounts for varying lift and drag on the blades as they spin. Initial calculations can start with the lift on stationary blades, but adjustments must be made for the dynamic conditions once the blades are in motion. Each blade segment requires analysis of airspeed and angle of attack to determine lift coefficients, which contribute to total drive torque. The overall model must also consider the turbine's impact on wind flow and incorporate control schemes for blade pitch and generator torque. Utilizing existing modeling software like FAST from NREL is recommended for accurate simulations.
Al-Layth
TL;DR Summary
I have a typical 3 bladed HAWT with a known blade and hub geometry along with full knowledge of the initial airflow (density, temp, pressure, speed). How can I model the motion of the turbine (RPM as a function of time) ?
the tldr covers everything I think. I don't expect there will be an analytic solution here lol. but I don't even know where to even begin formulating this problem mathematically. I assume I should find an expression for the initial lift on the blades, multiply by 3 and then model it as a circular motion problem?
But the problem is, that would only be valid for the instant t=0 and no time after it because:
(1) once the blades start moving, the lift per blade will be different too since the blades are now spinning whereas they were stationary at first.
(2) The spinning of the blades might create additional fluid effects that would distort the incoming airflow before it hits the blades.
So I'm mighty confused on how to deal with these issues in mathematical modelling.
You cannot really.
For any turbine RPM and wind speed, the angle of attack must be computed at each radial point along the blade. The lift and drag of each section along the blade must then be computed. Those forces must be integrated, and the angular acceleration of the turbine = "transducer disc" computed.
The solution will be a numerical solution as described in your quote below:
Al-Layth said:
I expect you will somehow need to calculate the lift on each turbine blade multiply by the number of them and model it as a circular motion problem. but then you also need to take into account the change of lift per blade due to the fact the blade will spin, (whereas it was stationary at first) and also the effects of the spinning blades on the incoming fluid as well. All issues currently beyond my modelling abilities
You start at the hub, and analyze the blade as a series of segments. Each segment has an airspeed, an angle of attack, and a radius. The airspeed and angle of attack allow you to calculate/find the ##C_L## and ##C_D##, from which you calculate the torque. Sum over the length of the blade, multiply by the number of blades, and you have total drive torque.
Total drive torque minus friction minus power generated equals net acceleration torque. Divide that by the total inertia and you have the angular acceleration at that point in time. Start at time 0, HAWT velocity 0, and select an appropriate time step. Integrate accordingly, then proceed to the next time step. Repeat until finished.
If the above is gibberish, you need to go back and study the fundamentals - physics, fluid dynamics, calculus, numerical analysis, and airfoil theory.
MTA: And that assumes a constant wind velocity and direction. The turbine will affect the wind in the vicinity of the turbine. But it's a good place to start.
Likes Al-Layth and berkeman
Your best bet is to use existing code. FAST, from NREL (https://www.nrel.gov/wind/nwtc/fast.html) is an excellent wind turbine modeling code that will do everything you want.
However, the most important factor in this is going to be the wind turbine's control scheme, both for blade pitch and generator torque, and I notice you haven't really mentioned it here. It's an incredibly complicated problem, so even if you want to design your own from scratch, I'd start by looking at what FAST does (luckily it's open source and there are a lot of papers using and describing it) and working from there.
Likes Al-Layth, berkeman and Baluncore
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
