Calculating the Efficiency of a Reversible Refrigerator
A reversible refrigerator with a coefficient of performance (COP) of 9.55 raises questions about calculating its efficiency. The efficiency formula, e = W/Qh, is complicated by the fact that refrigerators do not produce work output but instead use work input to transfer heat. Discussions clarify that for refrigerators, the COP is defined as Qc/W, where Qc is the heat removed from the interior. The confusion arises because the efficiency calculated from COP can exceed 100%, indicating that traditional efficiency definitions may not apply directly. Understanding the relationship between work input and heat transfer is crucial for accurate calculations.
ajmCane22
A reversible refrigerator has a coefficient of performance equal to 9.55
What is its efficiency?
COP = Qh/W
e = W/Qh
I thought e would simply be 1/9.55 = 0.1047 =0.105 (Sig. fig)
This answer was incorrect. Can somebody please help?
For one I am not sure how you are calculating efficiency since the refrigerator is producing no work output but using work input to move heat from a region of low temperature to a region of high temperature.
I don't know. That's the question in its entirety, and the answer is not 0, so there must be a way of figuring it out.
The problem will come in that your efficiency from a COP calculation can turn out to be more than 100%.
COP = Qc/W
Applying simple heat balance will give Qc=Qh+W
But W is your work input and Qh is your heat output.
COP = Qh/W
For a refrigerator, output is considered to be the heat removed from the inside. So COP (output/input) is: Qc/W. For a heat pump, output is the heat delivered, Qh, so COP is Qh/W.
So if they say the COP of the refrigerator is 9.55, this means Qc/W = 9.55
Like rock.freak I am not clear on what efficiency means for a refrigerator. Does the question provide any further information? Try W/Qh using W+Qc = Qh
AM
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
