Calculating the electric field
To calculate the electric field at the position of charge q_0 due to charges q_1 and q_2, the horizontal components of the electric fields must be determined using vector decomposition. The correct horizontal distance for q_1 is L/2 due to the equilateral triangle configuration, which affects the calculation of the electric field. The values obtained for the electric fields from q_1 and q_2 need to be adjusted to account for the cosine of the angles involved. The total horizontal component should then be recalculated by combining these adjusted values. Accurate vector addition is crucial for obtaining the correct resultant electric field at q_0.
symmet
Here's the problem:
Three charges are at the corners of an equilateral triangle as in the figure below:
....(+)q_1
.../...\ L
...q_0(+)____(-)q_2L = .06 m
q_0 = 1.8*10^-6 C
q_1 = 6.6*10^-6 C
q_2 = -4.6*10^-6 C
Calculate the electric field at the position of q_0 (the origin) due to q_1 and q_2.
Answer is a vector in terms of i and j.
My approach was to break down q_1 and q_2 into vector components. For example, to find the horizontal components, I did:
E_x = k(q/x^2)
where x is the horizontal distance from position q_0 and q is the charge. (k = 8.99*10^9)
So, plugging this in for both q_1 and q_2, I got:
q_1: E_x = -659266.67 N/C
q_2: E_x = 114872.22 N/CI put a - on q_1 because of the direction of the vector at q_0. Adding these together I get -544394.45 for the total horizontal component. But this isn't right. Can anyone tell me where I've gone wrong in my thought process? Thanks.
Do you know what the answer is?
Umm... well, it's a vector, so you would need a cosine for your horizontal q_1 field at point q_0.
It's online homework, so no I don't know what it is.
Well since it is an equilateral triangle, all sides are the same length L and all angles are 60 degrees. I know that the q_1 charge is L/2 away from q_0 horizontally because it is equilateral (and Lcos60 = L/2). That is what would be substituted for x in the equation.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
