Calculating the force on an electron from two positive point charges
The discussion centers on calculating the force on an electron positioned between two positive point charges, each with charge +q, located on the z-axis. While the mathematical approach involves calculating the electric potential and deriving the electric field, the intuitive expectation is that the electron should experience no net force due to the repelling nature of the charges. The confusion arises from the assumption that electric field lines do not interact, leading to the belief that the plane between the charges should have no field lines. However, field lines are merely a representation of the electric field and do not physically interact; thus, the mathematical calculations can yield a net force despite the intuitive notion of zero force. The key takeaway is that the mathematical treatment of electric fields does not align with the intuitive understanding of field lines in this scenario.
Antonis Hadjipittas
So this is more of an intuitive question rather than a mathematical one. I present the problem.
Assume I have 2 charges of charge +q at a distance r from each other on the z axis. Position of two charges is (0,0,r/2) and (0,0,-r/2). Assume now that I want to calculate the force these two charges exert on an electron which is at a point (x,0,0) or (0,y,0). Basically any point on the plane which lies on z=0, i.e. exactly between the two charges.
Mathematically the way to go about this, you calculate the electric potential for a system of charges and take both positive charges into account. Then you calculate the gradient of the electric potential which gives you the electric field and then find the force on the electron. If this is done correctly, you will find that there is a net force on the electron, however this is not intuitive to grasp. You see, since both charges are positive, the electric field lines should repel each other leaving the plane (x,y,0) in the middle with no field lines, therefore the force on the electron should be zero (Also assume that the electron's effect is minimal).
So my issue is the following: When we calculate the electric potential of a system of charges, we assume that the electric field lines do not interact with each other. If we assume that they do interact with each other, in this case we get a different answer since there should be no field lines in the plane lying exactly in the middle of the two charges. What am I missing?
Thanks in advance
Field lines are just a visual aid that we draw to help us see which direction the electric field points at any given point. They're no more real than the lines of latitude and longitude that we draw on a map of the earth, so they cannot attract or repel or anything else.
Where do we assume that such a thing, whatever its supposed to mean. You compute the potential, and then can derive the field lines from that. Not the other way around.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
