Calculating the Maximum Compression of a Spring
To find the maximum compression of a spring when a block is dropped onto it, the potential energy of the block (Ep = mgh) must equal the spring's potential energy (Ep = 1/2 kx^2). The initial equation needs to account for the additional distance the block moves down the spring, leading to the modified equation mg(h+x) = 1/2 kx^2. Solving this quadratic equation provides two solutions for x, with the correct maximum compression being approximately 0.142 m. The discussion emphasizes the importance of including the spring's displacement in the energy calculations.
soul5
A block of mass m = 3.4 kg is dropped from height h = 44 cm onto a spring of spring constant k = 1920 N/m (Fig. 8-38). Find the maximum distance the spring is compressed.
[PLAIN]http://edugen.wiley.com/edugen/courses/crs1650/art/qb/qu/c08/fig08_36.gif
Ep=mgh
Ep=1/2kx^2
Ok so I found the Potential Energy Ep=mgh. That energy should equal to 1/2kx^2.
So I set mgh = 1/2kx^2 to solve for x but my answer was wrong?
Your choice to use kinetic and potential energy is correct, but you are missing one small thing.
The distance the block moves down along the spring (that is, the distance the spring is displaced x) still counts as gravitational potential energy for the block. So modifying the equation you have to take this into account will yield:
mg(h+x) = .5kx^2
From here you can solve for x, the displacement of the spring. Since it is a quadratic, you will get 2 different answers, but it should be clear which one is the correct answer.
What was your answer for x, I got 0.1236m.
that's what I got to the first time, but it was wrong...
if you try what I mentioned you will get x=.142m which I believe is the correct answer.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
